¦U¦ì¨®¤Í¡G
¾ÇÀ´¾r¾p¹q³æ¨®¡A¬O¤H¥Í¤@¤j¼Ö¨Æ¡C¥Ñ¾Ç¨®¨ì·sµPªº´Á¶¡¡A¨C­Ó¤H³£·|¦³«Ü¦h°ÝÃD©ÎºÃ´b¡A·Q§ä¤H°Ý¬O³Ì¥¿±`ªº¨Æ±¡¡C­»´äªº¦h­Ó¹q³æ¨®·s»D²Õ¡A·í¤¤ªº¥D­n¥\¯à¤§¤@«K¬O¨ó§U¦³»Ý­nªº¨®¤Í­Ì¡C¥L­Ì¦³°ª¤âªø¦Ñªø´Á¾n¦u¸ÑµªºÃÃøÂø¯g¡C§ó¦³¨Ó¦Û¥|¤è¤K­±ªº¨®¤Í¥i¥H´£¨Ñ²Ä¤@¨­ªº¸gÅç¸É¥R¡C¦p¦³°ÝÃDª½±µ¦b·s»D²Õ¤¤´£°ÝªÖ©w¬O³Ì§Ö³Ì¦³®Ä¯qªº¤èªk¡C©Ò¥H¦³°ÝÃDÀ³¥ý¦b·s»D²Õ¤¤µo°Ý¡A¦pªG¤´¤£º¡·N©Î¯uªº·QÅ¥¦h¤@ÂI·N¨£¡AÅwªï¼g«Hµ¹§Ú­Ì¡Cª¾¹D¤@©wºÉ¤Oµª¡A­øª¾¹D«K·Óª½Á¿­øÃѵª¡A§Æ±æ¦U¦ì¦¬³f¡C
                      Email: mail@ibike.com.hk
ĵ§i¡G
¥»Äæ©Ò´£¨Ñªº·N¨£ÁöºÉ¶q«O«ù«ÈÆ[¤¤¥ß¡A¦ý¤´¥i¯à¦³µÛ¬Yµ{«×¤Wªº¥DÆ[©Î°¾¨£¡C
§Ú­ÌÁö¤wºÉ¤O½T«O´£¨Ñ¸ê®Æªº·Ç½T©Ê¡A¦ý¨Ã¤£«OÃҨ䥿½T©Ê¤Î§¹¾ã©Ê¡C
ŪªÌÀ³¼f·V¿Å¶q§Ú­Ìªº·N¨£¬O§_¦X¾A¥¿½T¡C
15/June/01
Dear Sir,
It is really delighted to visit your website and obtain so much valuable knowledge of motorcycling here. Having bought a second-hand bike, Suzuki GSX400, I as a beginner on motorcycling would like to seek your kind advice on the following:
1. For the captioned model, what kind of precautions should I take to regularly maintain and/or repair the bike properly?
Four Stroke engine is very reliable, if you do not have the owner handbook, try contact SBS Technology and see if they can spare one copy for you.  For generally speaking, routine servicing includes replace spark plugs /engine oil & filter /air filter several times a year, inspect/oil the drive chain and maintaining proper tension, examine the wears of your pair of tires and brake pads, check the brake fluid and coolant level is within the upper and lower limit's range. Use the bike everyday if possible, turn off the light when the engine is off, then your bike will be just fine.
2. What should be done if the bike is going to be left unused for certain period of time, say 2 months to better attain the bike's condition, and what should be checked in the first place after a bike is left unused for a long time?
3. Is it okay that a bike is left untouched for so long with a fuel tank full of fuel, especially in an open-air car park? should the 'big' stand be used in this case?
If your bike will be unattended for a while, say less than 3 months time, for good order sake you should do the following work before you go:
1) pump your tire pressure a little more than normal, e.g. 32psi to 45psi
2) disconnect the battery
3) Full up the fuel tank to avoid corrosion
4) Use the main stand to stand up the bike
5) Wrap the bike up with good immobile devices.
When you return, reverse the above procedures, if you find the engine idle speed is not stable after fully warm-up, then you better drain out all the old fuel, and refill fresh petrol.
4. What would be the causes if the engine would 'rumble' and the body of the bike would tumble slightly when i 'shut' the throttle riding on the highway at 3rd gear or so? is it normal? should I keep the throttle to fuel the engine a bit constantly to avoid this problem again?
It's difficult to estimate your situation, if you not comfortable with this, go and find an experienced guy to have a test ride.
5. What is '2T' oil, as it is frequently mentioned now and then in your website? should I use it as well on my particular model?
2T is only for 2 stroke machine, mixed with gasoline and burn in the combustion to do the lubrication job. 4 stroke machine don't need this.
6. Last not least, I wonder if you might advise whether and where I can get some complete details of my model's specifications so I can better understand my bike?
Thanks very much for your prompt reply and wish you and your website a prosperous year of 2001.
 Best regards  frankietalks@hotmail.com
15/June/01 ¥ý¦hÁ§A¤W¦¸·N¨£,§Ú½æ¥ª³¡zxr400¤ñpµP¤j¨ûo©Ô hehe!  ³o¬P´Á§Ú­«­è­è¶R¥ª³¡©ö­º hornet 600µó¨®,³¡¨®¦Í§A¦a­Ó¨p¤HÂàÅý¤J­±¶R¶ù,¯u­n¦A¦hÁ§A¦aibike.com.hk¥þÅéÉi¤H¡C
¤S­Ú§A·dÕi¡I¡HËݤj¨û³Ì«áÂI¼Ë·dµfÕi¥÷«OÀIo¬J©O¡H §Ú°O±o§AªG¬[¦n¦ü«YZRX400¡AÉA­ì¨Ó«YZXR400....
²{¦³¤@¨Çhornet 600 ¹s¥ó°ÝÃD·Q°Ý¦U¦ì¤j¨Ð¡G
1.hornet 600 ¥i¸Ë°v§â¶Ü? 2.§Ú¦³¤äÂÂ(NHK)ZXR400¥Î°v§â·Q¸Ë¦Íhornet 600«×­øª¾±o­ø±o?
Hornet 600 ·íµM¥i¥H¸Ë°v§â¡I¦ý«Y ZXR400ªº§â¤âÂà¦V¨¤«×«Y¯¶¹Lµó¨®o¬J¡A©Ò¥H¤ä°v§â·|¸ûµó¨®¥Îªºµu¡AÀ³¸Ó­ø¾A¦Xµf¸Ë¡C¦pªG¤@©w­n¸Ë¡A¥­¥­¦a¶R¤äNHK³»¦í¥ý°Õ¡C
3.½Ð°ÝÃä«×¦³ Hornet 600 ¸É«~½æ,¤Î¦³Ãö¸É«~¸ê®Æºõ¯¸©O?
Hornet600 d¸É«~¦n©öݯ¡A·¥ÅX©Î¨ÈªLÀ³¸Ó»ô®Æ¤S¦³®Ñ¥JÚ»¡Cºô¯¸ÉN¯d·N¼½¡I·Ó­psearch engine¤ºÁä¤Jhornet 600À³¸Ó¦³±Æ§AÚ»¡H
¯¬¤ë¤ë´«·s¨®(µoo¥ª¹FªG°¦) Lok  lok <lok@kolaraltd.com>
©Ó§A¶Q¨¥¡I¦ý«Y¥i­ø¥i¥H¦A³g¤ßd¡A­Ó­Ó¤ë´«·s¤k§r?
¨t°Ú64·³pµPª±ZXR400°Ú....«¢´X«l!!
ÂI¼Ë·dÕi¥÷«OÀI,§Ú«}¾Ç§A¸Ü,¥s¤j¨û¦Û¤v¥h°Ý¨ä¥¦«OÀI¤½¥qoù,¦pªG­ø¦Í§Ú³£µL­p¬°¦³¨ú®ø­ø½æ¤ñ§A,¥¿·íµL±æ®É¤j¨û¥´¹q¸Ü¤ñ§Ú¸Ü,¦Í¾r¾p¾Ç°|¦³­Ó¾É«Ó¥i¥H¦P¤j¨û·dÕi¥÷«OÀI,´X¤é«á­«¤ñ¥÷«O³æ§ÚÚ»¸ò¦í«}¥hÂਮ¥D¦Woù,¯u¨t­n¦hÁ¾r¾p¾Ç°|­Ó¾É«Ó,¦hÁ®Í!!
¯¬¤é¤é´«¤k(¥¿ªG°¦)  Lok 16 June 01
ËÝ«}§Y«YDay Day­Ú¤k­¸¡H
15/June/01 ±z¦n¡I ³Â·Ð§A¡A¤S­n°Ý°ÝÃD¤F¡G  spada250¤@¯ë¬O¤L¤L¦~¨î³yªº¡A³Ì±ß¤L¤L¦~©O¡H
                   ­P礼¡I            Jarod  jerryrice@263.net
Spada 250 = 88¦~12¤ë - 91¦~9¤ë¡A¨ä«á³QXelvis 250¨ú¥N
¡A bye!
13/June/01 §A¦n¡G
¥»¤H­è¦Ò¨ì¹q³æ¨®¡A·Q¶R¨®¡A¦]­è­è¤J¨Ó³o­Ó°é¤l¡A©Ò¦³±M¦³¦Wµü¤S¤£À´¡A¤S¨S¦³ªB¤Íª±¹q³æ¨®¡A°ÝçEÀY©Î½æ®a¤SÅå­Ú¤HÄF¡I½Ð°Ý¤°»ò¥s¡G
°v§â - Damper
³q±`¬O¤@¤äºÞª¬ªºªoÀ£µ©¡A³s±µ«e¤e©M¨®¬[¡A§Q¥ÎªoÀ£ªºªý¤O¨Óí©wÂà¦V§â¤âªº¹L±Ó¤ÏÀ³¡C¦]¬°¹q³æ¨®ªº§â¤âÂà¦V¬O1:1¡A¸ô­±ªºª¬ªpª½±µ¼vÅT§â¤â¡C¹ï©óÂà¦V¤Q¤À±Ó¾Uªº¶]¨®¨Ó»¡¡A°v§â¥i´î§C¨®¤â¦ÛµM¤ÏÀ³¤¶¤Jªº¤£¨}®ÄªG¡C
Fairing/°ØËï/½ÞÀY - ÂZ¬y
©M¨T¨®¬Û¤ñ¡A¹q³æ¨®ªº­·ªý¨t¼Æ¤Q¤À°ª¡A¦b¹q³æ¨®¥[¸Ë¬y½u§Îªº­·¾×¡A¯à´î§C­·ªý¡A§@¥Î¬O´£°ª·¥³t¡A¸`¬Ù¿Uªo©M«OÅ@¨®¤â¡A´î§C¯h­Â¡C²{¤µªº¶]¨®Fairing³s«áÃè¡B¨®°¼©M¨®§À³£¦³ÂZ¬y§@¥Î¡C½ÞÀYªº·N«ä¬O¸Ë¦b¨®ÀYªº¤p­·¾×¡C
§À¤ú- ¸Ë¦b§À½ü¤W³s±µ¨®Ã쪺¾¦½ü
¨¾ª£½¦ - Mushroom/PK½¦, ¸Ë¦b¨®¬[¤Wªº¥VµÝ§Îµw½¦¡A´î»´¶^¨®®É¹ï¨®¬[©Î¤ÞÀºªº¶Ë®`
¤j§áªo- ¹ï©óÁɨ®¤â¨Ó»¡¡A¥þ¶}ªoªùªº®É­Ô¤Q¤À¦h¡A¤j§áªo¸Ë¸m¬O´î¤Öªoªù¥þ¶}®É¡A¤âµÃ©Ò»Ý­nªº§á°Ê¨¤«×¡A´î¬Ù¶}ªo®É¶¡¡C§Ú­Ì»{¬°¤pºø¦Ï¤]À³¥[¸Ë³oÃþ¸Ë¸m¡A¥i´£°ª¾r¾p¼Ö½ì¡A¿O¦ìµ¥°_°Ê®É¡A¤âµÃ¤£¥²¦Q°_¦¨°¦Åb©CËݼˡG)
¥|¾B¥]³½ -  ¥|¬¡¶ë¹ï¦V´w°Ê¥d¹X¡A°ª©Ê¯à´w°Ê³¡¥ó
¿û³ï - - ´w°ÊªoºÞ¥~¼h¥Ñ¿ûµ·Â´¦¨¡A¥Ñ©óªoºÞ¤º®|¸û¤p¡A¬G©Ò»Ý¤O«×¸û¤Ö¡C¥D­n¥\¯à¬O´î§Cªo³ï¦]¼ö¿±µÈ¡A´£°ª´²¼ö¯à¤O¡AÁקK­¢¤Oªo¦]§l¦¬°Ê¯à²£¥Í°ª·Å¦ÓªmÄË¡C
§Öcam¤ú - §Îª¬§ó¦yªøªº¥Y½ü¡A¯à´£°ª¤ÞÀº»Öªù(valve)ªº¶}±Ò¨¤«×¡A¦b°ªÂà®É¯à®e³\§ó¦hªo®ð¶i¤J ¿U¿N«Ç¡C
kit½ñ/kit³ï/kit­·¹j - ¦b­»´ä¡Akitªº·N«ä¬OÁɨ®¤Æ¡C¤É°ª¸}½ñ²Õ¥ó¡A¼W¥[¨®Åé¶É±×¨¤«×¡Aª½¥X¦¡¦º®ð³ï¦b°ªÂà®É¥O±Æ®ð§óºZ¶¶¡C°ª¬y¶q­·¹j¤]¥O¤ÞÀº¦b°ªÂà®É¥i§l¤J§ó¦h¥Í­·¡C
§Ú²{¦b·Q¶R¶]¨®¡]¦]«¬¥J¡^¡A¦ý§¤±o¦n¦ü¦n©¯­W¡A¤SÃø±±¨î¡Aµó¨®¡A¤SÅå©Ê¯à­ø¦n¡C§Ú¤ß¤ôÚ»¤¤
CBR250RR©ÎCB400,­Y§Ú¸êª÷¥u±oHK$7,000-12,000¡A­þ°Ê«¬¸¹ªº¤G¤â¨®±À¤¶¦X§Ú³o­Ó·sµP¥J¥Î¡H ³£«Y¥­è°¥¿©ö±±¨î´N³Ì¦n°Õ¡I¡I¦hÁÂÀ°¦£ ·sµP¥J¤W fungsiulun@ctimail3.com 13 June 01
²{¤µªºµó¨®©Ê¯à¤Q¤À±j«l¡A¤£¥Î¾á¤ß¡C¶]¨®ªº³]­p¬O¥H³t«×©M©Ê¯à§@¥Xµo¡AµÎ¾A©Îºû­×»ù¿ú¤£¬O½Í½×ªº¶µ¥Ø¡CÚ»§A­Ó´Ú³£«YÄÁ·N¶]¨®¡A¥[¤W¦³­­¹wºâ¡A©ö¥Î¤Íµ½ªºCBR250RRÀ³¸Ó´X¦X¾A¡C
½Ðª`­«¾r¾p¦w¥þ¡A§A¥H¬°¹q³æ¨®¦n¦³«¬¡A¦ý«Y¨ä¥L¤H­ø«YËÝo©À¡C§Ú·í§Aè°¥J¹LRicky Martin¡AÃMDucati 916¡A¦b¤k¤H²´¤¤¡A³£­ø¤Î¤@­Ó¤­§`¥úÀY¦Ñ§|ja¬[ªLÄ_°í¥§¡u©Ê·P¡v¡C§Ú­ÌÀ³¸Ó¨É¨ü¹q³æ¨®µ¹¤©§Ú­Ìªº¤è«K©M¦Û¥Ñ·P¡AÃM¨º¤@´Ú¹q³æ¨®¡A¤Ï¦Ó¬O¦¸­n¡C
¦hÁ§AªºÄ_¶Q·N¨£¡A¯uªº«D±`¤§·P¿E¡A§Úı±o§AÚ»³¥Ú»±o¦n³q³z¡A¤S¤@¥Ú¤¤¡Aµuµu¤@«Êe-mail«K²M·¡§Úªº©Ê®æ¡A§Ú¤Q¤À³ßÅw§A³Ì«á¨º¬q»¡¸Ü¡C§Úı±o«D±`¦³Point!! Thank you very much!!
·sµP¥J¤W fungsiulun@ctimail3.com  14 June 01
11/June/01 §Ú¬O¤@¦W·sµP¥J¡A­èÁʤJ¤@³¡°¶¤hT5¤è¿O200CC....¦ý¬O¤£ª¾¦]¦ó°ÝÃD¨£¨ì§A¥ç¦³»¡©ú¹L¡D©ó4/Juneªº¦^À³¤¤¡D¡¨§A¦bµó¤W¨£¨ì¤@¨Ç¤G½ÄVESPA¦b°±¨®®É§À¿O®É¤j®É²Ó¡A¥i¯à¬O¦]¬°¾÷¥ó¦Ñ¤Æ¡A¹q¤O¿é¥X¸û®z¡A«åÂà¤]¤£Ã­©w¡A©Ò¥H¿O¥úÀHµÛ¤ÞÀºÂà¼Æ¤£¦P¦Ó²£¥ÍÅܤơC§Ú¥H«e³£¦³³¡¦L«×¦Ï¡AÉN¹q¦ÀÉN«ü´§¿O¡AÀY¿O´N«YËݼˡA§áªo´N¥úD¡A­ø­Úªo´N·tD¡A­ø«YËݦw¥þ¡C ¡¨
§Úªº¨®²{¦b´N¦³³o­Ó°ÝÃD¡D´«¹q¦À¥i§_¸Ñ¨M°ÝÃD¡D¦³®É³sµÛ¨®³£¥X²{°ÝÃD¡D½Ð°ª¤â«üÂI¤@¤U¤p§Ì¡D´«¹q¦Àªº¸Ü¥]¸Ë¤u$280¤S¬O§_¤Ó¶Q©O¡HÁÂÁ¡I¡IBilly pp88@hkem.com
°_°Ê°¨¹FªºÁn­µ¬O§_¯h®z¡H¦pªG¦³«lªº¸Ü¡A¥i¯à¬O¤õ©CÀã¤F¡Cªy¨®«áoff ªocord¯à¨¾¤î¤õ©C§ËÀã ¡C¦pªG¬O¹q¦ÀÉN¤O¡A§ó´«¹q¦À¬O²Ä¤@¨B¡CHK$280ÂIºâ¶Q¡H§A³¡¹q¸Ü¶R¦h¹q³£­ø¤î©O­Ó¼Æ°Õ¡C
08/June/01
Your web is very useful to everyone ,,,, but  the Chinese word  is too small,,,,, so if the Chinese word can use bigger font ,, it will be more easier to be read by your readers,,,,, thanks...and   when should  the   cooler water  be changed ,, and how to change  ,,, u can reply it in chinese,,, thanks very much ,, and have  a good business
wilson pa6095@y28.com
½Ð°Ý§Aªº¹q¸£¢á¢ë¢ú¢í¢í¢ö ¸Ñ¹³¢û¢í¢ü¢ü¢ñ¢ö¢ï¬O1024 x 768 ¶Ü¡H°£¤FÅKÃM«H½cªº¦rÅé¢û¢ñ£C¢í¥Î¡u10¡v¤§¥~¡A¨ä¥L©Ò¦³¤º¤å³£¬O¥Î¡u12¡v¢î¢÷¢ö¢ü¡CÀ³¸Ó¤Q¤À¨¬°÷¡C½ÐÀˬd»Õ¤UªºÅã¥Ü«Ì³]©w­È¬O§_°ª©ó1024 x 768¡A§Ú­Ìªº³Ì¨ÎÂsÄý³]©w¥u¬O800 x 600°Ú¡I
¤ô½c¤ôÀ³¨C¹j¨â¦~«K§ó´«¤@¦¸¡A°ò¥»­ì²z¬O©î¥hªo¬û¡A«Ý¤ÞÀº§¹¥þ§N«o«á¤~§á¶}¤ô½cÁ`»\¡]¨Ã¤£¬O¨®¤¤¶¡§À½ü¤Wªº°Æ¤ô½c¡^¡A¸òµf±ø¤ô§N®MºÞ³ï¡A¸Ñ¶}±µ¤J¤ÞÀº©³³¡ªº³s±µ¤f§â§N«o¤ô©ñ¥X¡A«Ý¤ô ¬y¥ú«á¦A§â¥¦±µ¦n¡C¦b¤ô½c»\­Ë¤J·sªº§N«o²G¡]²{¦b³£¬O±Ä¥Î¤w²V©M¦nªº§N«o¾¯¡^ºCºC­Ë¦Üº¡Âm¬°¤î¡A¤£­n¯dªÅ¦ì©Î®ðªw¡C¦A§â¤ô½c»\®êºò¡Aµo°Ê¤ÞÀºÅý§N«o¤ô¬y¤@·|¡A¦A¥´¶}»\¬Ý¬Ý¬O§_»Ý­n¦A²K¥[¡A³Ì«á¬Cºò¤ô½c»\«K¥i¡C
§N«o¾¯ªº§@¥Î¬O¨¾ùר¾µ²¦B¡A¨}¦nªº¤ô§N¨t²Î°£¤F­n¦³¨¬°÷ªº§N«o¤ô¥~¡A§ó¦³¿à
1)¨t²Îªº±K«Ê©Ê - ´£°ª§N«o¤ôªºªmÂI¡AÁקK²£¥Í®ðªw´î§C§N«o¤ô»P¤ÞÀºªº±µÄ²
2)¤ô¸ô´`ÀôºZ³q - ®MºÞ¨S¦³¥ÍùשβJ¶ë¡A¥O§N«o¤ô¯à§Ö³t¦a¬y°Ê
3)´²¼ö®°¤ù§Îª¬¥¿±`©M°®²b - ¯à«O«ù³Ì¤jªºªÅ®ð±µÄ²­±¡A±a¨«¼ö¶q
·íµo²{¤ô·Åªí¶W¶V¥­®Éªº°ª«×®É¡A¥Nªí§N«o¨t²Î¥X¤F°ÝÃD¡C²Ä¤@¨B³Ì²³æªº«K¬O§ó´«¤ô½c¤ô¡C
08/June/01
§Ú¬[X9­Ó¹q¤l¿öªO¤SÃa¥ª!!!«Y¤J¤ô¦Ó¥t¨ìD¿ö¥X°ÝÃD,¶Ì¤U¶Ì¤U!¤µ¦¸¥¼ª¾¬O§_­n¤ñ­×²z¶O,§Ú¥u«Yª¾¹D¤µ¦¸¥N²z¸Ü¤@©w­ø·|´«·s¿ö,¦]ÉN³f·Q´«³£ÉN±o´«!3500¤½¨½Ãa¨â¦¸¿ö¤@¦¸·¥¤O¤l,«ç¿ë¦n?
³s·N¤j§Q¥Í²£°Ó³£§ë¶D¹L,¤£¹LÉN¦^­µ!!!­ø³q­»´äD¦Ñ¹q¯u«YÉN¦a¦ì?¦P¥N²z¶R¨®¤S¦³¦ó¥Î?°I¹L¶R¤ô³f,«O¥Î¬O¤°»ò?¥H«á¦³¾÷·|¦A¶R¨®³£«Y¶R¨®¦n,̼¥ª¤Q´X¬[³£¥¼¸Õ¹LËÝ·Ð!¨®¥X°ÝÃD¥u¦³©Ç¦Û¤v²´¥ú­ø¦n,·s¨®¥X°ÝÃD¤S§ë¶DµLªù............!!!      ¥]¥J hoikong@bike.com.hk
«Y·s»D²Õ¨£¨ì§A¸Ü­n«Y¶ø¤hªù¤f¿N¨®Ø{¡I¤d¬è­ø¦n§r¡A¶O®É­Úĵ¤è¸Ü§AÁa¤õ©Ôµf¥h§r¡I¨ä¹ê¤S­ø¾pËݳҮð¢÷¬J¡AX9ªº¹q¤l«}¿ö¬O²Ä¤@´Ú¦PÃþ²£«~¡A¦b³]­p¤W¤@©w¦³§ïµ½ªÅ¶¡¡C²£«~³]­p¤£µ½¡A¥u­n¤£¯A¤Î´Û¶B©Î¦M®`¤H¥Í¦w¥þ¡A®ø©e·|±ýÀ°µLªù¡C­Y·Q¤Þ°_¨®°gÃöª`¡A¬Û«H¥ç¤wµL¤H¤£ª¾¡C¥u¦³±H±æ±N¨Ó¢æ¢¸ ¢´¢¯¢¯¤£·|µo¥Í¦PÃþ±¡ªp¡C
 ¦b¦Û¥ÑÄvª§ªº°Ó·~ªÀ·|¸Ì¡A²£«~¥X¤F°ÝÃD¡A¼t¤è¤@©w·|©Ó¨üÃe¤jÀ£¤O¡A©Ò¥H­Ó¤H¬Û«HPiaggio¼t¤è°ª¼h¤@©w¤wª¾¹D³o¥ó¨Æ¡A¥u¬O¥i¯àÊ\¦a·t°×©³°µºò¢÷³¥§Ú¦a­øª¾¢÷ªÌ¡I
08/June/01
§Ú·Q¶RRunner180¡A­ì¥ý·Q¶R4½ÄªO¡A¦ý§Úı±o3°¦¨®¨­ÃC¦â³£¤ñ2½Äªº®t¦n¦h¦n¦h¡A¦Ó¥B¤S¤ñ2½Ä¶Q$5000¡]¦¨20´X­Ó%¡^¡A¦]¦¹·Q¦Ò¼{2½ÄRunner¡A¦ý¨ä¹ê§Ú§^«Y¤ÓÁé·N2½Ä¨®¡C½Ð°Ý¡G
1)  2½ÄRunner«Y«}o±pªoD¡H®t´X»·¡H
¤G½Ä¤ÞÀº¦]¿U¿N®Ä²v¤£¤Î¥|½Ä¡A©Ò¥H·|¥Î¦hDªo¡A¦ý¥H180cc±Æ®ð¶q­p¡A¬Û®t¤£·|¤Ó»·¡C
2)  ­@¥Îµ{«×¦³µL¤À§O¡Hºû­×¶O®t´X»·¡H
¶Ç²Î´¼¼z¸Ü­Ú§Úª¾¡A¤@©w«Y¥|½Ä­@¥Î¡C¤G½Ä¨®¦pªG­ø«Y¾A·í½d³ò¨Ï¥Î(¤ÓºC)¡A·|¿nºÒ«Ë¡A°Ê¤Oªí²{·|¨Cªp·U¤U¡C¦ý¤G½Ä¤ÞÀººû­×¸û²³æ¡A¤H¤u¥i¯à·|¸û«K©y¡C
3)  ¨®¨­¾_°Ê¦³µL¤À§O¡H
¤j®a³£«Y³æ½L180¡A¬Û«H¾_°Ê¤À§O¤£¤j ¡C
4)  2Tªo¶O¥Î¡H´X­@¥[¤@¦¸¡H
´X¤Q°A¤ä2Tªo¡A¦³¥­¦³¶Q¡A¦Û°Ê²Vªo³ý¨ì¹Flow®É«K­n²K2Tªo¡A³q±`´X¬ûªo¥ý¤J¤@¦¸¡C
5)  ¦pªG·s¨®¡]4½Äª©¡^¥h¼Qªo«Y«}§^À³¸ÓËÝ°µ¡H
±ð«Y­ø¦n¼Q°Õ¡A¸Ü®Í·s¨®§¹Éܪo¨«¥hµf¼Q¡Ao®{­øo®{§r¡H
°ÝÃD¦ho¥ªD¡A§^¸Ó®Í¡I    rick <rick@freeforum.org>
ÁöµM§A­øÄÁ·NVXR¨®ªá¡A¦ý«Y·í§A§¤¤W¨®®É«Y¨£­ø¨ìo¬J¡C¦ý«Y¦pªG§A­øÄÁ·N¤G½Ä¨®(­Ó§âÁn¡H)¡A¥u­n¤@µÛ¨®¡A§A«K¥²»Ý­n­±¹ïÉN±oÁסC¦pªGo©ÀµÛªø ja¡A´z¥|½ÄVXR¡A¹L±o¤@¨â¦~¡AÂÂo¥ª¥ý®³¥hµf¼Q§Aªº¤ß·R¨®ªá¦n­ø¦n¡H¡C
07/June/01
±z¦n,  ¥»¤H¬O·sµP, 21·³, ·Q¶R¤@¥x400ccªº¨µ¯è¨®,¬O§_¾A¦X? ¦Ó400ccªº¨µ¯è¨®¦³shawdo, vulcan, dragstar.., ½Ð°Ý­þ¤@¥xªº©Ê¯à¸û¦n,¸û©ö«O¾i?? shawdo400 ªº·s¨®»ù¬O¦h¤Ö? ¥t¥~,­·§N©M¤ô§NªºÀuÂI©M¯ÊÂI?  ½Ð¦h¦h«ü±Ð!! ÁÂÁÂ!!   raymond_fung@hotmail.com
400¨µ¯è¤T¤Q¦h¤Çªº°¨¤O·s¤âÀ³¸Ó¨S¦³°ÝÃD¡C¬ü¦¡¨µ¯è¨®³ÌÁ¿¨s«¬®æ¡A©Ê¯à¤j®a³£¬OOHC¤ÞÀº¡A­«§á¤O¤£­«·¥³t°¨¤O¡A©Ò¥H°ÝÃD­«¤ß¤£¦b¦¹¡C«O¾i¤è­±§A´£¨ìªº¨®´Ú³£Äݨ}¦n¡A§A¥u»Ý±M¤ß´z¥~«¬³Ì¦X§A¤ß¤ôªº¨®§a¡G)Shadow400¦n¹³¨S¦³·s¨®¡H¤£¤Ó²M·¡¡C
­·§NªºÀuÂI¬O«O¾i©M»s§@³£¸û²³æ¡A¤ÞÀº­«¶q»´«K¡A¨®»ù¤]¸û«K©y¡C¯ÊÂI¬Oªø´Á°ªÂà³t¹B¦æ¥i¯à·|´²¼ö¤£¨¬³y¦¨¹L¼ö¡C¤ÞÀº¹Ô¤ù¤]¸û©öº¯¥XÔUªo¡C¤ô§NªºÀuÂI©M¯ÊÂI­è¦n©Mªo§N¬Û¤Ï¡C
¨ä¹ê¤£¥Î¤Ó¾á¤ß­·§Nªº«¬¸¹¡A¨®¼t³]­p¤w­pºâ¦b¥¿±`±¡ªp¤U¨Ï¥Î¨S¦³°ÝÃD¤~·|¥Î­·§N¡C§CÂà¼Æ¡A§CÀ£ÁY¤ñªº¤ÞÀº¥Î¤ô§N¦³ÂI®ö¶O©O¡I
05/June/01 ºô¥D:
§Ao¦a¦n!  «Ü¦hÁ§Ao¦a´£¨Ñªºª¾ÃÑ©M¸ê°T, ¤p§Ì±o¯q¤£¤Ö. ªñ¨Ó¨£°¦°¶¥K¦Ñ¦Ï, °±¨®®É¨®¨­¾_°Ê±o«Ü§Q®`, ¦æ¨®®É¥ª¸}(¥­±`©ñ¸}¦ì)¥ç·Pı«Ü¾_, ¦³§_¤j°ÝÃD©O? ¥t¥~, ¥ò¦³¤@­Ó¤p°ÝÃD: ¦]¥»¤H¬O·sµP¥J, ¨C¦¸¥hªo¯¸¥[ªo, ¦A¦Û¦æ¥[2T«á, ¨º¨®³£«ÜÃøµÛªð¨®. «Y«}¥[2Tªº¤èªk¤£¥¿½T(§Ú¤w¸gºCºC­Ë)?  ·PÁÂÀ°¦£!
m2k   m2k@sinaman.com
½Ð°Ý·í®É¬O¨«¦h¤Ö¤½¨½©O¡H¦pªG§Aªº¦Ñ¦Ï¦b70/80km/h®É®t¤£¦h¥þ¨®³£¾_°_¨Ó¡A§¤¹Ô¤]¶Ç¨Ó°w¨ë¦¡ªº¾_°Ê¡A¨ºª¬ºA¦n·¥¦³­­¡C«Øij¦^¼tÀˬd¨®¬[©M¥Ö±a¡C§A»¡¡u¨C¦¸¥hªo¯¸¥[ªo, ¦A¦Û¦æ¥[2T¡v¡HÀ³¸Ó¥ý­Ë¤J2Tªo¡A¤~¤J¨Tªo¡C¥Î·N¬O§Q¥Îªo³ïªº½Ä¤O¡A¨Ï2Tªo©M¨Tªo¯à¥R¥÷²V©M¡C
05/June/01 ¯¸ªø±z¦n!  ¥»¤H¬O·sµP¤@¦W¡A·Q¥X³¡¢C20,000¥ª¥kªº¨µ¯è¨®¡C³Ìªñ¦b¨®¦æ¨£¨ì¤@³¡¤G¤âªº96¦~Virago250¡A½æ $19,300 ¡A·Q½Ð°Ý»ù¿ú¬O§_¦X²z©O¡H¥t¥~¡A°²¦p¥Î$25,000¶R³¡¥þ·sªºRebel250¡Aªø»·¨Ó»¡¡A¦b«O¾iºû­×¤è­±¬O§_¤ñ¸û¦Eºâ©O¡HÁÂÁ¡I
ªü­¸   bon_hui@hotmail.com
96¦~ vs 01¦~¥þ·s¨®¡H»ù¿ú¥u¬O¬Û®t$5,700? µª®×Åã¦Ó©ö¨£¤£¹L°Õ¡I¬Ý¨Ó»Õ¤U¤£¤Ó³ßÅwRebelªºª½¤GÔU¡A¥u³ßÅwViragoªºV2ÔU¡A§_«h¤£·|¤´¦b¦¹¶O¯«¦Ò¼{¡C«O¾i¤£µ½ªº¸Ü¡A¬Û®t¤­¦~ªº¾÷¥ó¥i¥H¦³«Ü¤j¤À§O¡A»ù¿ú¬Û®t¤£¤jªº¸Ü¡A·íµM¬O¥þ·s¨®¸û©è¶R¡C
04/June/01 ±z¦n,  ¥»¤H¬O·sµP,·Q¶R¤@ºø¦Ï¥ï¨B, 20year old, ¥X«OÀI¦³µL°ÝÃD?¤ß¥Ø¤¤·Q¶Rvespa, PX200 or ET8, ¦ý¤£ª¾¦p¦ó¼¶¾Ü,¥»¤H³ß·RPX200¥~«¬, ¦ý¬O¤G½Äµ{, ·l¯Ó·|§_¸ûET8 ªº4½Äµ{§Ö, ©y¥B¥»¤H¦bµó¤W¨£¨ì¤@¨ÇVESPA ¦b°±¨®®É§À¿O®É¤j®É²Ó, ¤£ª¾¬O§_VESPAªº®zÂI, ¥i§_µ¹¤©¤@¨Ç«Øij, ÁÂÁÂ!
¤g¤H  tsz_wang@yahoo.com
²{¦æªº§ë«O±ø¥ó¤Q¤ÀÄY®æ¡C23·³¥H¤U¡AµPÄÖ¤£¨¬¤@¦~¡A¥X«OÀI¤Q¤À§xÃø¡C¤j³¡¥÷«OÀI¥N²z³£¤£©Ó°µ³oÃþ§ë«O¤H¥K¡C§Y¨ÏªÖ©Ó°µ¡A·|¥[°ª©ùªºªþ¥[¶O¡A»ù¿ú¤Q¤À¶Q¡C
°²³]§A¸Ñ¨M¤F«OÀI°ÝÃD¡APX200©MET8¤§¶¡¡A«Øij¿ï¾ÜET8¡C­Y¯Â½×°¨¤O¡A·íµM¬OPX200¸û¨Î¡C¦ýET8ªº¥|½Ä¤ÞÀº¤ñ¸ûÀô«O¡A¥~«¬¤]¸ûº}«G¡A¾÷¥ó¤]¸û¤G½Ä¤ÞÀº­@¥Î¡C¤G½Ä°¶¤h¬O¤@»O«Ü¦³©Ê®æªººø¦Ï¡A©ö¦³¤p°ÝÃD¡A¦ý¤S¦n©ö·dµfÕi¡C«O¾i¦nªº¸Ü¡A¥i¥H«Ü­@¥Î¡C¦ý­»´ä¤j³¡¥÷³£¬O¥Î§@¤u°Ó¥Î³~¡A­ø«Y¦Û¤v¨®¡A«O¾i±ð«YÉN¸ò±oËݺò¡Cª¬ºA¦ÛµM¥¼¹F³»®p¡C
04/June/01
½Ð°Ý¥D«ù¡A¥»¤H·Q´«¹q³æ¨®¡A­n¨D¦p¤U¡G ¸gÀÙ¡B¹ê¥Î¡BáǪo¡A¸g±`¨Ó¦^¤EÀs¦Ü¯»À­¡A¦æ¨«°ª³t¤½¸ô¡A¨®³t¤@¯ë¤£¶W¹L¸ô¼Ð­­¨î¡A¥N¨B¨®¡C½Ð¤¶²ÐµP¤l«¬¸¹¡AÁ`¤§­n¥­¦n¥¿ªº¥þ·s¨®¡I ½Ð«ü±Ð¡I
Sam Wong ptming@netvigator.com
¥þ·s¨®¯à²Å¦X§Aªº­n¨D¡A±j¯P±À¤¶Suzuki GS500, Kawasaki ER-5¡A¥¦­Ì³£¬O500¯Åªº¥|½Äµ{Âù®ð¬ûµó¨®¡A¤ñ¥|®ð¬û¤ÞÀºáǪo¡C°¨¤O¶W¹L50ps¡A§á¤O¤ñª½¥|400µó¨®§ó±j¡A¤]¤ñ250µó¨®§ó¾A¦Xªø³~°ª³t¬ï®Þ¦U°ª³t·F½u¡CGS500±Ä¥Î­·§N¤ÞÀº¡AER-5¥Î¤ô§N¡A©Ò¥HER-5»ù¿ú·|¶Q¤@ÂIÂI¡A¦pªG¤À´Á¤ë¨Ñ¡A¤Ü¥|´Á¨C´Á¤£¹L¬O¤G¤d¦h¤¸¡C
04/June/01 §A¦n!!!
     ¥»¤H·Q°Ý¤U¦³ÃäºØ¹q³æ¨®¾A¦X·sµP¥J¦Ó¥B¤S®É±`³£­n¦æ°ª³t¤½¸ô?¨ä¹ê¥»¤H·Q¶Rºø¦Ï¨®¡A¦ý¤S©È¦æ°ª³t¤½¸ô­øÕi.....±ø°ª³t¤½¸ô¦³¦¨110km/h. ­ø¸Ó®Í!!!    °ÝÃD¤Ö¦~  vigor_chiuwan@hongkong.com
³o­nµø¥G»Õ¤Uªºª÷¿ú¹wºâ¦Ó©w¡C¦pªG·sµP½m²ß¡A«Øij¶R250©Î400µó¨®¡C¦ý§A·Q­nºø¦Ï¡A¨º250ºø¦Ï¦ü¥G¬O§Aªº­º¿ï¡C­ní©w¦aªø³~¶]110km/h¥H¤W¡A³Ì«K©yªº¿ï¾Ü¬OFusion 250¡A©ÎMajesty YP250¡C¦pªG­nº}«G¤@ÂIªº¡A¥i¿ï¾ÜForza 250¡C¥H¤W©ÒÁ¿¨®´Ú»ù¿ú¥ÑFushion¸U¾l¤¸°_¦ÜForza 250·s¨®¤­¸U¾l¤¸¤§¶¡¡C
¨ä¹ê·sµP¶RCB250©ÎEL250¤]«Ü¤£¿ù¡C¬J¥i½m²ßÂàªi ¡A¤S¥i¸gÀÙ¦a¥N¨B¡C¾Þ±±®e©ö¡A¤]«ÜµÎ¾A¡C¦Û¤v°á°á¡C
02/June/01 ¥»¤H­è¦¨¬°¨®¥D,¥ç¬O²Ä¤@¦¸¦¨¨®¥D,¨®¬Obandit 400¤Q¦~¨®,½Ð±Ð°ÝÃD¦p¤U:
1.ªo¶O­n¦¨$1¤@¤½¨½¶Q¤£¶Q,¦Ó¥»¤H¦]¦h¦b¥«°Ï¦æ¨®±`¶ë¨®,±`¥Î¤@¦Ü¤Tªi,·|§_¦]¦¹¦Ó¥O¯Óªo¶q´£¤É,
¦p¦h¦æhighway·|§_áǪo¨Ç??
2. «çª¾´X®É­n´«¤õ©C, ­·¹j, ¹q¦À¤ô, ¹q¦À, ªo¹jµ¥µ¥,¤S¦]¨®ÄÖ¤Ó¤j·Q½Ð°Ý¨º¤@¤è­±­n¯S§Oª`·N. «O¾i¹q³æ¨®³Ìºò­n¨º¤è­±??
3. ¥»¤H180½S, ¦Ó­L®ð28«e30«á¹ï¶Ü??
4. lowªi®É¦³¦¨¤G¤dÂॿ½T¶Ü??
¦hÁ½ç±Ð     resident@iloveilove.com
400cc ­n¦¨°A¤@¤½¨½¡AªÖ©w¦³°ÝÃD¡C§Y¨Ï«åÂà°ª¡A¸g±`¶ë¨®³£­øÀ³¸Ó¦³ËÝ°ª¡C¦]¬°¥¿±`¬ù¦b$0.6¥H¤U¡C¯Óªo¶q¤j¡Aªí¥Üªº°ÝÃD½d³ò¥i¥H«Ü¤j¡A¨Ò¦p¿U¿N®Ä²v¡A°Ê¤O¶Ç°e³£¥i¯à¦³°ÝÃD¡C¦pªG¥¼´«¹L¡A«KÀ³¸Ó§Ö¢Ò´«¢÷¥ª¢Ò®ø¯Ó«~¡C¤õ©C¡AÔUªo¡Aªo¹j¡A­·®æ©O¥|¥óÄ_ª«¡A¯Ê¤@¤£¥i¡C
¥H180 lbÅé­«¡A­L®ð28/32 psi·|¦X¾A¢Ò¡C¦pªG±ø§À­L«Y¥¿±`ªº¸Ü¡A»P¦a­±±µÄ²«á¯d¦b§À­L¤Wªº²ª¸ñ¤£À³¶W¹L¤T­Ó¤â«ü¦ì¡C
Slow«åÂ঳¢±¤dÂà¤Ó°ª°Õ¡A°£¤F¼W¥[¯Óªo¶q¥~¡A¤]´î§C¢Ó¢ö¢ï¢ñ¢ö¢í ¢ê¢ú¢é¢ó¢ñ¢ö¢ïªº®Ä¯à¡A¦¬¨®¯à¤O´î®z¡C«åÂणÀ³¶W¹L1200rpm¡C¦pªG½Õ§C«åÂà¦Ü¥¿±`°Ï°ì·|¦º¤õ¡AËݳ¡¨®´N¯u«Y­øºë¯«¡C´«¤F¥H¤W©Ò´£¤Îªº¥|Ä_¤§«á¡A±¡ªp¤´¨S¦³§ïµ½ªº¸Ü¡AËÝ´N­n¤J¼t¢ë¢ð¢í¢ë¢ó¡C¤Q¦~¨®À³¸Ó­nÄá«z¨Ð¡C¤]¦³¥i¯à­n©ï³¡ÔU¥X¨Ó­×²z¡A¨Ò¦p§ó´«·l¯Ó¤Fªº¾B¹aµ¥¡Cµø¥G¤W´X¤âªº¨®¥D«O¾i¦p¦ó¡C
02/June/01 §A¦n!¥Ñ©ó³Ìªñµo²{ªo¬û©³¦³¤£¤Ö¨I¾ýª«,©Ò¥H·Q©óªo¬û»P¤Æªo¾¹¤§¶¡ªºªo³ï¸Ë³]fliter¤£ª¾·|¤£·|¦³¥ô¦ó°ÝÃD?   heil heil@sinaman.com
¤£·|¦³°ÝÃD¡A»Õ¤Uªº±¡§Î¸Ë¢Ô¢ñ¢ô¢ü¢í¢ú¸û¦n©O¡C¦ý°O±o©w´Á²M¬~/§ó´«ªo³ï¢Ô¢ñ¢ô¢ü¢í¢ú¡C
02/June/01
¥D«ù§A¦n:
    ¶Qºô¯¸¬°§Ú¼W¶i¤£¤Ö¦Ñ¹qª¾ÃÑ,¦b¦¹»¡Án¦hÁÂ!!!
    ¥»¤H¬O¤@¦W18·³¡A¥¿¦b¾Ç¦Ñ¹qªº¤Ö¦~¡C¦³¼Æ­Ó°ÝÃD·Q½Ð¦U®v¥S®v©jÀ°¤p§Ì¸Ñµª¡C
  1. PGM 3 SP ¡BV2 SPR ¡BRGVÃä³ï¡A¨º´Úªº¾Þ±±¸û¦n¤Î¨C¤@´Ú¬ù´ä¹ô¦h¤Ö©M¦³¦h ¤Ö¤Ç°¨¤O?(½Ð°Ý¦U¨®¦³ÉN¤@¨Ç¯SÂI?¦p­n¦æªø³~¥ý§Ö¡C)
  2. ·sµP¥J¨Ó»¡¦³ÉN¸ÜÃä¤@´Úªº¨®¤ñ¸û®e©ö¥X¨ì¤T«O¤Î¨ä¹ê«OÀI¦p¥þ«Oµ¥?
  3. ¥»¤H¨ì¹L¤¸®Ô°Ï¼Æ°Ý¨®¦æ°Ý¹L¤@ÃD°ÝÃD¡A°ÝÃD«YD¤H±`±`³£»¡RGV³o¼Ë­ø¦n­Ó¼Ë­ø¦n¡A¨ä¹êRGV¯u¥¿¦³D«§°ÝÃD©O?§Ú³£¥h°Ý¹L¤@¨Ç¾r¾pRGVªºªB¤Í­Ì¥L­Ì³£»¡RGVÉN«§°ÝÃD´í¸¨­«¦n¦n²K¡A«Y¤£¹L­nKIT°ªDÂà¼Æ²ßºD´NÉN¨Æ!
  4. ¥»¤H¦]­Ó¤l¤ñ¸û°ª¤jªº¦³179CM¡A¤]·Q¹L¶R¤@¬[400CCªº¦Ñ¹q­øª¾¦U®v¥S®v©j·|«Øij¤p§Ì´í¥|½Ä400CC OR ¤G½Ä250CC©O?      ¦h¦h°ÝÃDªº¤Ö¦~!_! cholera@hongkong.com
¦U´Ú¤é¥»¤G½Ä¶]¨®¦b¤é¥»¦b92/93¦~¦¬ºò°¨¤O±ø¨Ò«á¡A¤@«ß¥u¦³40ps¡C¥u¦³V2 ©M RGVªº¥X¤fª©¤~¦³70ps°¨¤O¡C¦ý¯d´ä¤´¥Í¦sªº¼Æ¶q«Ü¤Ö¡C¸Ô²Óªº¾Þ±±¤À§O¡A­n°Ý¹L¦U¨®¥D¥ýª¾¡C¦ý³£¤£Â÷¤G½Ä¤ÞÀº¯S©Ê¡A§Y§CÂàµL¤O¡Apower band¤ñ¥|½Ä¤ÞÀº¯¶¡A»Ý­nkeepÂà¼Æ¦æ¨®¡CºC¨®©ö¤ôºu¡A¤õ©C©ö¿n¬´¡A°ªÂà¼Æ¬±¨®®É¬ðµM¥þ¦¬ªoªù®e©öÉN2Tªo¨ìo®³óo"lum"ÔU¡A¥Õ·Ï©M¾¸­µ³£¬O¤G½Ä³]­p³Q®É¥N²^¨Oªº­ì¦]¡C©Ò¥H¦U¤é¥»¨®¼t§¡Ãö³¬¤F¤G½Ä¶]¨®ªº¥Í²£½u¡A²{¦s¦b´äªº¤G½Ä¶]¨®¡A½è¯À©Mª¬¯à®t²§¥i¥H«Ü¤j¡C­Ó¤H­ø¬Û«HRGV·|¤ñ¨ä¥L¤G½Ä¨®®t¡C¦ý¬y³q¶q©M¹s¥óªº½T¤ñ¢Þ¢Õ¢ÛÃø§ä¡C
¹q³æ¨®¤@¯ë¥uÁʶR²Ä¤T«O¡A´Nºâ¦³¥þ«O¶R³£¦n«Ü¶Q¡A¤£¤Æºâ¡C¦Ó®a·sµP¥X¤T«O³£¦º®Í¤õ¡A­ø°÷¤Ü¤T·³¡AµPÄÖ­ø°÷¤@¦~¡A³£´XÀY²ª¡C¥H«e¥X«OÀI¥D­nÚ»µPÄÖ¡B¨®ÄÖ©M±Æ®ð¶q¡A©Ò¥H¥Xºø¦Ï·|¥­¢Ò¡C¦ý¦Ó®a¡D¡D¡D¡D
Å¥§ÚÁ¿¡A©ñ±ó¤G½Ä¨®¡CÂà¶R¢³¢¯¢¯§a¡C¤K¤Q¦~¥N¯Z°ª¤â­Ó­Ó³£«Y¶¼¤G½Ä¨®¢Ò¥¤¤j¢÷¬J¡A©Ò¥HÃø§K¤´¹ï¤G½Ä¨®«O¯d±¡·Nµ²¡A¬JµM»Õ¤U«Y·sµP·s®É¥N·s¤HÃþ¡A±ð«Yª±¥|½Ä¨®°Õ¡I¦Ó®a¢Ò¤j¥|½Ä¶]¨®¤S»´¤S©ö¾Þ±±¡Aµ¥ª±¼ô¢÷¥ª¬[¢³¢¯¢¯«á¡A¤É¤W¢µ¢¯¢¯¯Å´X¦n³£¦³¡I
Æ[¬Ý¥H©¹¨Ó«H May  Apr   Mar   Feb
ĵ§i¡G
Copyright ©1999-2001 ÅKÃMºô»x  www.iBike.com.hk   All Rights Reserved ª©Åv©Ò¦³   ½Ð¤ÅÂà¸ü
