ENGINE
Design | Single-cylinder, 4-stroke, spark-ignition engine, liquid-cooled |
Displacement | 690 cm³ |
Bore | 102 mm |
Stroke | 84.5 mm |
Performance | 49 kW (66 hp) |
Starting aid | Electric starter, automatic decompressor |
Transmission | 6-speed, claw shifted |
Engine lubrication | Semi-dry-sump lubrication with 2 rotor pumps |
Primary gear ratio | 36:79 |
Secondary gear ratio | 16:42 |
Cooling system | Liquid cooling system, continuous circulation of cooling liquid with water pump |
Clutch | APTC™ Anti-hopping clutch / hydraulically operated |
Ignition system | Contactless, controlled, fully electronic ignition system with digital ignition timing adjustment |
CHASSIS
Frame | Tubular space frame made from chrome molybdenum steel, powder-coated |
Fork | WP Suspension Up Side Down 4860 ROMA |
Shock absorber | WP Suspension 4618 with Pro‑Lever linkage |
Suspension travel front | 250 mm |
Suspension travel rear | 250 mm |
Brake system front | Disc brake with radially mounted four-piston brake caliper; floating brake disc |
Brake system rear | Disc brake with single-piston brake caliper, floating |
Brake discs - diameter front | 320 mm |
Brake discs - diameter rear | 240 mm |
Chain | 5/8 x 1/4¡¨ X‑Ring |
Steering head angle | 63¢X |
Wheel base | 1,480¡Ó15 mm |
Ground clearance (unloaded) | 270 mm |
Seat height (unloaded) | 925 mm |
Total fuel tank capacity approx. |
12 l Unleaded premium fuel (95 RON) |
Weight without fuel approx. | 142 kg |
