2010 Piaggio MP3 LT 300 ie/400 ie
新車速報 11 Nov 2009 |
| 隨著Piaggio集團的278cc單缸引擎上架,世上第一臺以傾斜式轉向的雙頭輪綿羊Piaggio
MP3 250,在宣佈會在2010正式升級為MP3
300(400仍然健在)。新舊引擎的馬力輸出的分別,焦點在於更低轉數和更高扭力。駕駛者即使以同一步伐前進,駕駛MP3
300會感到較為輕鬆。 |
Piaggio is proud to present the MP3
LT, the only scooter that you can ride with a driver's licence.
Today the smallest of the LT range, the 250, has grown to 300.
The new engine capacity means greater benefits in terms of both
performance, with more thrust at lower speeds, and of consumption,
which is optimised with the adoption of the innovative Ride By Wire
system for electronic throttle grip control. MP3 LT 300 also goes
beyond the type approval restrictions of the 250 to gain full access
to ring roads and toll motorways. Derived from the revolutionary
Piaggio MP3 range, MP3 LT maintains all the MP3’s advanced
solutions, as well as the safe, fun riding characteristics that have
made the first three-wheel scooter such an outstanding success.
The dimensions of a compact maxi scooter combined with amazing
agility make the Piaggio MP3 LT completely at home in the city
centre where it is also safe and easy to park thanks to an
electro-hydraulic system that locks the front suspension and allows
it to stand upright even without the aid of its stand.
Piaggio MP3 LT boasts incredibly short braking distances that are
unmatched by anything else in the scooter world: Thanks to a triple
disc braking system and the exceptional grip afforded by the two
front wheels, stopping distances are 20% shorter than those of the
best conventional scooters. When the road leaves the town behind,
the Piaggio MP3 LT really shows what it is made of. Road holding,
cornering safety and lean angle unattainable for conventional
scooters guarantee immense riding satisfaction on fast country
roads.
Thanks to its larger front track of 465 mm, the Piaggio MP3 LT can
be ridden by holders of a normal driver's licence even though it is
equipped with powerful 300 and 400 engines offering far greater
performance than the 125 cc engines to which driver's licence
holders were previously restricted.
Piaggio MP3 LT is available in two engine sizes: 300 and 400. Both
engines are ultra-modern, powerful but ecological 4 stroke units
with four valve heads and liquid cooling, and conform to the most
stringent European emission standards. Engine performance has been
increased in the mid-size range, from 250 to 300, to maximise
pick-up and acceleration, essential qualities for both city
commuting and tourist use.
The brand-new 300 cc also boasts an absolutely impressive
technological supremacy: use of the highly advanced Ride by Wire
technology for the electronic throttle grip control. The Piaggio MP3
300 ie does not have any mechanical connection between the throttle
grip control and the throttle valve located in the intake duct that
modulates the amount of air to mix with the petrol. The
result of the electronic control is an optimised air/fuel mixture,
which turns into smoother power delivery and therefore into enhanced
riding comfort. Lower consumption and fewer emissions.
The Master 400 engine is a 4-valve, 4-stroke unit with liquid
cooling and electronic fuel injection. This engine is the top of the
LT range with a power output of 34 bhp at 7,500 rpm and 37.6 Nm of
torque at 5,500 rpm. |
Piaggio
MP3 LT 400 ie (300 ie) – Technical Specifications
Engine |
4-stroke single cylinder |
Engine capacity |
398.9 cc (278 cc) |
Bore x stroke |
85.8 mm / 69 mm (75 mm / 63 mm) |
Power |
34 hp at 7,500 rpm (22.5 hp at 7,500 rpm) |
Torque |
37.6 Nm at 5,500 rpm (24 Nm at 5,750 rpm) |
Timing system |
Single overhead camshaft (SOHC) - 4 valves |
Fuel system |
Electronic fuel injection (with Ride By Wire control) |
Cooling |
Liquid |
Lubrication |
Wet sump |
Starter |
Electric |
Transmission |
Twist-and-go CVT with torque server |
Clutch |
Automatic, centrifugal dry clutch |
Frame |
Double cradle in high strength tubular steel |
Front Suspension |
Articulated quadrilateral consisting of four aluminium arms
sustaining two steering tubes, and pull rod suspension geometry
with offset wheel axle - Wheel travel: 85 mm |
Rear suspension |
Double dual action hydraulic shock absorber with adjustable
spring preload - Stroke: 110 mm |
Front brake |
Two 240 mm discs |
Rear brake |
240 mm Ø disc |
Front wheel rim |
Aluminium alloy 12" x 3.00 |
Rear wheel rim |
Aluminium alloy 14" x 4.50 (14" x 3.75) |
Front tyre |
Tubeless 120/70-12” |
Rear tyre |
Tubeless 140/70-14'' (140/60-14”) |
Length/Width |
2,180 mm (2,130 mm) / 745 mm |
Front track |
465 mm |
Wheelbase |
1,550 mm (1,490 mm) |
Seat height |
785 mm (780 mm) |
Fuel tank capacity |
12
litres |
